A few questions...
Well I ended up just taking a hacksaw to my crank as the pedal was on there good and took off the chain finally. So after a couple months I am finally down to just a frame.
Now I am just looking over the nooks and crannies of this thing. Is it best to just take a wire brush and get the build up off of everything that way?
Also the kick stand, how do I get it out of the sleeve holding it to the frame? The sleeve is welded to the frame. Would it be best to just torch it off? I can probably salvage the actual kickstand, just need to get all the rust off.
Primer. When putting on the primer and paint, what parts of the frame should I mask off? Are there any spots that if painted could affect performance, i.e. bearings?
Thanks in advance!
Thanks in advance!
