I have a bad cog that's bent and I need to figure out how to change out either the cog, or chain wheel if I can't get the right size cog. I want to keep the same ratio or make it slightly easier to pedal (lower ratio?).
It has a 44 tooth chain wheel and a 22 tooth cog. If I put the original 19 tooth cog back on, what number of teeth does the chain wheel need to keep it nearly the same or lower? I can get a 36 or 40 tooth replacement for the chain wheel. What will work best?
