ok - ive got a major problem - been re-doing a 1960 huffy belair - and the front forks were loose and when i tried to tighten them i noticed the top bearing nut, the one that had the cone on bottom for the bearing , was lopsided - so i disassembled the head tube, removed the bearings and on closer inspection the threads at the top of the tube are bent - ...? -no wonder that nut and stuff was terribly difficult to get off - i assume i will need to replace these forks now - bummer because wanted to keep them as they were original - is there any way to disassemble and keep forks and replace the tube only ???
-help please --
-help please --
