Help ID a coaster brake hub
Aug 20, 2009
4,202
107
Derby, KS
1   0   0
I know I need pics, they will be up tomorrow. I have a hub with a skip tooth sprocket. The brake arm is missing and I cannot find any markings on the housing, although it is pretty nasty. The hub housing itself is not the typical plain cylinder shape, but more of a ''barrel'' shape with two raised bands in the middle. The bands are about 1/4'' wide and 1/4" high with 1/4"-1/2" gap in the middle. The sprocket has a gap through it from the inside out. The spot where the brake arm mounts is a square 3/4"- 1".Any suggestions from the discription? If not I will post the pics in the morning. I have the matching set of wheel and no use for them. I just want to be able to list them properly when I put them up for sale. Thanks!
Sounds like a musselman hub, they made some for Elgins and JC Higgins bikes that had some fins on the outside of the hub shell. They were marketed as "aircooled" hubs.
yup sounds like an elgin hub (i didnt know musselman made them) the ony set ive had that sound like what your describing said ELGIN on the brake arm.
I went and checked Sheldon Brown's site and the guts of the hub I have look like a Musselman hub, but the housing I have is different. I think you are right about it being a Musselman though. I will get some pics up tomorrow.
Musselman made a bunch of coaster hubs without the "aircooled " fins. The finned hubs were for Elgins and Higgins bikes only. Of all the coaster hubs I have rebuilt I think the Morrows stop the best with Musselman a close second.
Ok, I think I lost a few too many brain cells when I was younger because the hub looks nothing like I described :? . Here are a few pics of the hub and the innards.
I have a hub like that on my wifes 1941 Elgin. I've heard it called a Elgin air cool, but you know theres a lot of names out there that not always right.
Since this hub found its way back to me today I thought I would fire up the way-back machine and bring this thread back to the top. While the Musselman internals are the same as the Elgin/Higgins air cooled hubs the shell is not the same. Anyone know what brand bike wore this hub when it was new?
