Finally found an old monark springer fork, and I need some help to make it fit my build off bike.
First, four bolts at fork blade ends to pivot plate, do longer bolts go on front or back?
Second, head tube on my bike 5 1/4 inches, steering tube on fork if I put bearing race as low as possible 5 3/4 inches. What is the best remedy, have a machine shop tap threads 1 1/2 inches farther down steer tube? Then would I have them make me a spacer to fit under headset locknut? should that be threaded?
Any other suggestions would help. Thanks!
