Thanks..After It started working with the WD40..I just took some automotive gear lube and let it soak into the bearings and clutch assembly...Put it back together, and it seems fine....thanks for the info.Oh, heck yeah! Those little pawls inside are probably all sticky. I usually drench the clutch assembly with Tri-Flow. The WD-40 will work for a while, but it isn't as long lasting as most true lubricants.
