- Joined
- Sep 17, 2013
- Messages
- 4,278
- Reaction score
- 9,446
I got the leather cut and wax hardened. It was hard from just the regular wet and dry hardening but after the wax cooled it is almost like plywood.
I cut it with a razor knife and it fit perfectly. I held in place for the cutting with clamps.
Wax hardening makes it a nice dark brown. The pox marks are from the Bondo scratch filler. The scratch filler also gave the leather a pink stain on the pox marks. If you do this fill in any imperfections in your female mold with plaster. The ACME logo embossing is very shallow and light because a lot of the depth came out with the pressing and heating for the wax saturation.
The dents in the side of the leather are from plaster cast areas that I did not smooth out well. I thought it was smooth, but it wasn't. I used the Bondo scratch filler here on the sides and it must expand when it is wet for a few days. It also discolors the leather (it came out darker after the wax saturation). The leather picks up every nuance of your mold so I learned to be more careful if I do this again.
The leather also shrunk a little with the hot wax hardening. I will have to grind a little off the pan to make it fit. Next step after fitting it to the pan is to sand the leather to make more rounded contours as the razor knife left some small angles instead of contours. It should look old when it is finished.
