I didn’t know about spray-arc either, in relation to structural welding, but I knew it was used to do things like build up bearing surfaces and crankshafts. An old welder taught me how to do this 25 years ago.
We were welding 3/16” & 1/4” angle & T sections into gridwork.
We used a Lincoln suitcase wire feeder with a WW-2 era Lincoln 300 transformer for the power. We were able to crank the wire feed and the heat virtually all the way up, and weld very fast.
How you knew you had all the settings just right, aside from the beautiful weld, was that it suddenly got quiet!
He got a clean beautiful weld with no slag, and it was silent. You heard the machine run, but you didn’t hear the sizzling-popping of a typical weld.
I don’t know why that is, but maybe it has something to do with having oxygen in the gas? The welding needed very little cleanup. Basically they washed it, and etched it, and hot-dipped it.
The only time you got any dingleberries was at the very start of a weld, or if you got sloppy. I’ve never seen anything like it before or since, except for TIG welding, and it was like 5 times as fast as any Tig welder.
