I know, I know ... there are many ways to accomplish this same feat!
If you like to run internal gear multi-speed hubs such as the Nexus or Sturmey Archer on a vintage frame, chances are you’ll need to spread the rear dropouts to accommodate the extra axle width.
If you have fresh paint and find yourself alone, Neanderthal methods may not be the best course of action.
This little tool works like a charm and you probably have the parts just lying around.
Parts needed:
1 axle
2 axle nuts
2 seat clamp halves
and a chunk of 2-3” of some fat hose or rubber cut in half to protect your paint.
With the wheel in position, preferably with the bike upside down, simply slide the assembly between the chain stays and between the spokes and snug it up by hand, checking to make sure its seated correctly to prevent any damage to your paint.
Next, turn the nuts with an open end wrench, equally on both sides.
Eventually the rear dropouts spread the necessary width and the rear axle slides effortlessly into place.
Now, simply loosen the axle nuts and carefully remove assembly.
No stress and best of all, no paint damage!
Parts needed:
1 axle
2 axle nuts
2 seat clamp halves
