As long as you did over, over and then under you are fine for a three cross pattern.
You may as well try, only way to learn!Thanks for the encouragement as I am building a wheel and will try to true it myself. If I screw up, the bike shop will be able to fix it, if I don't mess it up too much.
I did put the valve hole in the gap thankfully, I have noticed in the past that that is where it should be. I actually did true it up on a flipped over bike but checked for true by clamping a screwdriver to the fork with my hand while spinning with the other. Came out good, but pretty sure with a bigger rim or one that was bent to start with the zip ties would be the go. I actually have 2 dial indicators here to build a truing stand at some point, but doubt I will ever get around to it...You see how the spokes are positioned just below the "3" in the picture?
Notice how it is a nice wide gap? That is where your valve stem hole needs to be, in one of those gaps, if you don't already have it there. I can't tell for sure from your pictures. You can either weld up the hole and redrill if it is in the wrong position, or just shift your spokes over a few holes. (I'm kidding about the welding, Luke...!!)
As far as truing goes, nothing is as cheap as your present bike and a pair of zip ties attached to the fork or chain stays to act as a truing stand.. If a rim is already bent before you try and build a wheel from it you may have a difficult time getting it to true up.
I was going to go with dial indicators too, but bought a $60 stand when I realized I'd have that much into one I built myself. Having this stand I realize that dial indicators would be over kill. The zip ties rubbing the rim are plenty true enough. JMHOYou may as well try, only way to learn!
Yeah, think I will end up with the zip tie trick...I was going to go with dial indicators too, but bought a $60 stand when I realized I'd have that much into one I built myself. Having this stand I realize that dial indicators would be over kill. The zip ties rubbing the rim are plenty true enough. JMHO
Rebuilding my first coaster was fun too as you said, that 'Coaster Culture' video makes it easy, as the loose ball conversion makes a huge difference...Congrats Luke, looks good to me!I hope your health improves as fast as wheel building skills. I agree, its a simple process lacing a wheel and truing one....I always thought the worse part was figuring out spoke length. It's similar to rebuilding hubs, lots of fear, but once you get your paws into it you realize a caveman could do it
