JCPenny Hydrauilc Disk 10 Speed
Oct 28, 2018
1,654
1,297
I found this and I think it is more impressive than the Sears one I posted a while ago. http://www.ratrodbikes.com/forum/in...peed-from-sears-with-hydraulic-brakes.109951/
Here we go. Like the Sears, it is Murray built.
Yesterday, I did some research, and it seems to be a mix of mechanical and hydraulic. There is a normal brake cable that works with a normal drop bar lever. The cable pulls up a lever on the brake like a normal, mechanical disk brake, but the mechanical lever operates a hydraulic piston in the brake. There is a see through reservoir on the brake that is filled with green hydraulic fluid.
Pretty much, a mechanical cable activates a hydraulic piston, so it uses a normal lever and cable setup, but the normal lever and cable operates a hydraulic piston in the caliper.
