expjawa said:There are some I've seen that used an inertia switch as well. It was self-contained in the light housing; when the bike decelerated quickly enough, the switch closed and lit the light. I'm not sure who made them or how well they worked, though.
I'm guessing moe of a problem downhill, but would have to be fairly steep if set up properly, hopefully! :?The_Black_Monark said:, some Phantoms used a ball-bearing switch. When slowed the light would come on. Probably when going up hill too!
LukeTheJoker said:I'm guessing moe of a problem downhill, but would have to be fairly steep if set up properly, hopefully! :?The_Black_Monark said:, some Phantoms used a ball-bearing switch. When slowed the light would come on. Probably when going up hill too!
Do you have a link for that?NicksGarage said:There are some new brake lights that use accelerometers like in a Wii or smartphone to turn on the brake light. They also use it to turn on the taillights when ever the bike is moving.
Sent from my EVO using Tapatalk 4
stersam said:Do you have a link for that?NicksGarage said:There are some new brake lights that use accelerometers like in a Wii or smartphone to turn on the brake light. They also use it to turn on the taillights when ever the bike is moving.
