With the width of the rear hub on these other wheels, may have to convert and space the bottom bracket. I got a small one piece but not in 1/8
Yes, you are right. Need a wider BB.You might look at a fat bike specific BB. Of course, you will have to widen the BB on the frame to accommodate it. Most are 100 mm if I'm not mistaken.
Regaurding the seat stays, pie cuts will not solve it. If you use a tape on your diagram, youll see that thelength from post to stay brace actually grows. Youll be better off just grafting in the correct length piece. Else youll still be splicing in a section somewhere.To bend the top tube back, will be spreading the chainstay and seatstay tubes. Plan to pie cut them and bend them in as i bend the seat tube.
Anyone know a good pie cutting template sw that might make it a little easier? Else will draw them in by hand.
Need 190mm wide at the dropout. Funny how plans change as the bike starts to speak...
Good point, I still need to adjust for the cranks, they wont fit yet. Might need four slices on the chain stays instead of two to get it right, if i have to narrow the distance between inmer and outer cuts.Nice work, will the stays still clear the cranks and chainring?
And adding some curve to the seat tube as i widen the stays, should help keep distance from tire to seat tube consistent. Almost have the jig mapped out in my mind that i will be clamping over it to ensure it all stays square.Awsome can make up for any length lost in the drops... by spreading that way youll pull the drops twords the bb.. if you messure the length of the stock tracing vs the mock up youll see you lost some distance... thats how mutch closer the wheel will be to the bb and seat post
Yes, it sure looks nice and is durable, but as hard ad my head when trying to remove it...Powder coat... a friend and enemy.
They are making that frame look smaller than I anticipated.They should look awesome on there!
Hoping so. Slow moving, but will get there.This is gonna be a cool fatty!
Capricorn... I'll keep butting it in till the fatty fits.......as a Crowned Piscis I know would say.....
MO FATTA MO BETTA!
Still planning the dropout mods to fit a 10s derailleur. Plan to extend the right side dropout down. Shape not yet decided though... [emoji48]mmmmmm...gears.....can't wait to see this fat muscle.
