One of my things i do is go to the flee market and buy bikes in the same size for parts some times .
Well the action of the springer still works fine. I haven't road tested it yet to see how well it works... still in the mock up stage.These fork extensions seem to work well with the bolt set up of a springer fork. What does it do to the compression / rebound action of the fork? Dive at all in the corners? I definitely like the laid-out look of it on your build! I would have to incorporate something like this for me on a >26" sized wheel bike...food for thought....
Can you provide a photo of the bottom bracket shell with the cups that are installed, give me a better picture to reference in helping to solve. Maybe if you can, the I.D. of the actual BB shell (frame portion) to see what is available for adapter or other....The issue now is that I want to go from this tiny 32t chain ring to a 39t. Looking on EBay I can find nothing like this or anything to convert...
The cups are 40mm and the BB installs just like an American 1 piece crank. No threaded cups they press in. SO, I am stumped as to what to do without major modification. The chain ring that is on it is machine pressed on. Luke suggested grinding it off and welding in the chain ring... I am not a big fan of that considering that I would have to $$ someone to do it.
Ok, here you go. The opening is 40mm and it is non-threaded, just like an old school American bike... set the cup in and smack with a rubber mallet. The crank shaft is 16mm. The shaft itself is 127mm in length.Can you provide a photo of the bottom bracket shell with the cups that are installed, give me a better picture to reference in helping to solve. Maybe if you can, the I.D. of the actual BB shell (frame portion) to see what is available for adapter or other....
Both of those are too large for this frame. 68mm is standard American sized BB. The ones I need are 40mm.This would be a fairly reasonable fix. This BB set up with the adapter and bearings and spindle included. Found some online for ~$16.
http://www.jbi.bike/web/checking_product_description.php?part_number=22147
http://www.niagaracycle.com/categories/pyramid-m-x-3-piece-bottom-bracket-set-conversion-kit
Then right and left crank and a 39t chain ring to finish it off. See my PM.
