Looking forward to seeing someone to swap the tires out for those new Felt ZigZag tires...
Should look and ride pretty cool!
I love those forks! Where/What are they?ED-PV-
Man that turned out great! Great look!
Is the electric drive a kit, or something that you put together yourself. Got any links?
On a side note:
I got my fork on last night:
very nice! what did you use to cut that thick metal?Thanks! I made those forks. That bike is full suspension now.
heres a beast of a beast.
Its a standard rear motor with a 7 speed freewheel 135 mm. I had to do some clever spacing with the torque arm and washers to space it right. And there are no threads coming out of the tightened axle. Its real close but will work the hard part is finding the bracket for the dusc caliper to fit on. It usually found with a chunese kit front motor.How did you do the long axel conversion to the electric motor?
I want to add a front motor to the bike in Post #567 But the axle between forks measures 144mm.Its a standard rear motor with a 7 speed freewheel 135 mm. I had to do some clever spacing with the torque arm and washers to space it right. And there are no threads coming out of the tightened axle. Its real close but will work the hard part is finding the bracket for the dusc caliper to fit on. It usually found with a chunese kit front motor.
The bike is one of my faves. I would love to see what you do with cars.Here is my contribution to the Mongoose Mod Thread
View attachment 6679 View attachment 6680 View attachment 6681View attachment 6682 View attachment 6686
This is what the bike ended up being
View attachment 6688 View attachment 6689 View attachment 6685
Thanks, What I have done with cars is a subject for a different thread...The bike is one of my faves. I would love to see what you do with cars.
- by Gigmata
Yea, you got it.This bike is CRAZY cool! Are the tires painted Beasts?
Yea, you got it.
I painted them with Plasti-Dip white.
Something in the rubber of the tire made it patina almost immediately.
This just added to the look of oldness.
Cool!Yea, you got it.
Yes, Plastidip does adhere very well I guess as long as you don't skid your tires...Does the plastidip hold up to actual use? I wouldn't think so but maybe it's that good.
- by Gigmata
