I rebuilt an old morrow hub for my latest build, but the grease I used in the rebuild is apparently a little too greasy. What can I do to make it a little less slick so the brake grabs a little better? It has the little screw and tab that lets you squirt grease in to the hub. I wonder if there is some sort of friction modifier that I could put in there to change it up. The mechanics of the system are moving and working fine.
I guess I can strip it all down and take off all the grease, but what do i put back on it?
