Ok I must be plagued with Nexus brake problems. I stuck one on the frame I'm building. It worked fine till you hit the brakes. Makes a loud squalling noise. I have several more , so I took the inside out of another and stuck it in that one. Same deal...squalled like a run over dog. So I think its a hub problem. Changed to another wheel. It did it too. So the only common denominator is I cleaned them all inside and lubed them with some expensive Phil Woods waterproof grease. I called Shimano....waited in line for 10 minutes to talk to a zip that had no idea what I wanted the answer too. He must be a reel guy , because he sure doesn't know anything about their hub noises. So now I can only come up with you have to use Shimano grease on one of them. They have come up with a new deal where they dunk the bottom part in some Shimano oil ( trans fluid works too )for a few minutes and then let it drip for 5 minutes . Then you lube just the brake ring with their grease. Another cool thing I found was you turn the chrome cover on the brake side and a little hole will appear and you can add grease without taking anything off....I didn't know that. :roll: :shock: So if anybody has this problem and has an answer tell me ...if not I am going to solve it and will post the answer when I get it.
