Problem with disc brake hub adapters
Jan 21, 2009
10,863
16,338
Zambales, Philippines
8   0   0
I was converting a couple bikes over to disc brakes and found a problem with the adapters that thread on to a non disc hub.
They attach clockwise and the rotor gets attached to the adapter as if the hub was made for a disc brake.
I also used a adapter to attach the caliper to the frame, but I haven't used them yet to give any info. I have a front disc brake on this bike and it works fine.
Unless you are rolling backwards then there's a problem. The hub adapter unscrews because it doesn't lock in place. The rotor will come loose from the hub. As long as I don't rely on the brake when rolling backwards it will work fine.
Normally the rotor is solidly attached to the hub.
It doesn’t have threads all the way to the tip. The tip is the same diameter as the root of the threads, and they extend about beyond the threads.
The length of that nose can vary with the application. This is a typical one with the standard dog point.
A dog is something that mechanically locks. Like the bolts on a bank vault door.
I call them set skrews now I know the actual name.
I've got coaster brakes on the rear just in case. But I think it will tighten up with some heavy braking as it's the front wheel, to where it won't break free, like a cluster that needs to be hammered on to get loose after using for awhile. For my big heavy fatbike, both hubs are made for disc.
If it is aluminum and steel threads, eventually the threads will corrode and lock the aluminum in place with a bunch of rust. That might secure it forever. It won’t happen if you put Loctite or paint or something on those threads.
Of course normally you would just use bicycle grease, but not in this condition where you don’t want it to unscrew.
Anytime you screw an aluminum part to steel you have this potential for massive gallvanic corrosion that locks the two parts together.
There are several styles of set screws commercially available, with different styles of points and heads.
Square point, dog point, cup point, round nose, etc.
There’s one that holds the handle on my shower faucet knob, which is a long dog point, & the point is five times as long as the threaded portion. It goes clear through the shaft, valve and handle too, acting as a pin rather than a clamp.
The cup point is the most common and it’s normally found on pulleys with round shafts.
In my experience this only have happened with stainless steel.
I didn't think it was a good solid front brake after all, so I put it back to a side pull brake. I could have also done a band brake but this is the most reliable. Any time I want disc brakes, a disc hub will be the only way to go.
The 32 tooth chain wheel and 22 cog give an easy cruising gear, 53 and a low low 38, just right for an old guy.
