Right, so I've got a '63 Typhoon. Primary issue now is the front wheel has got a good bend in it, so I'm set on changing the wheels to something less enamel white and adding a set of black 26x2.35 Fat Franks. Then I got to thinking how cool a 2 speed kickback hub would be for higher speeds, so of course now is the time.
So I've been researching (corrections welcomed)... If so equipped from Schwinn, my bike would have come with a 36 hole, 3 red band kickback, that gives me a shorter gear in addition to my standard gear. There was also a 28 hole kickback with 3 blue bands, and its second gear was an overdrive. That's what I want. I'm guessing these came on Stingrays due to the 28 holes. Yellow band kickbacks came in either configuration.
To make a short story longer, I want a two speed kickback with a taller (overdrive) gear in addition to my stock gear, and the 36 holes for 26" wheels. Since the Stingray had short 20" wheels, I don't know if putting that hub on a 26" bike would be a good idea(?) It would be one tall geared mother! How can this be done??
