Im in the process of installing a 7 speed Sturmey Archer on my stretch Micarge cruiser (originally a single speeder). Got a couple questions.
Firstly, Im having issues adjusting the gears. I did some searching and found the link to that site about adjusting SA 3 speeds. Problem is, Ive adjusted it as tight as the SA provided cable bracket allows, and there's still way too much slack. When I put it in 1st, I can pull the cable out almost an inch because there's so much slack in the cable :? As I shift up, the slack is slowly taken up till when its in 7th the cable is tight. I'll see if I can get some pics.
The other issue is the SA grip-shift shifter doesnt fit the bars. There's probably a few mm difference between the diameter of the bars, and the inside diameter of the shifter. But there doesnt seem to be any tightening/fastening mechanism to screw it down? :? The stump grip (the non-twisting part of the grip of the shifter set up) fits fine on the bars though.
Any assistance will be gladly appreciated! Thanks
Oh yeh, this is my first play with cruisers/multi-speed hubs.
