Seat placement is perfect now!
Great song & GTB I will do sir!Jake Sensi said:This silent assassin is making alot of noize!! so crank up that PE " bring the noize" and GTB!!! PEACE
kingfish254 said:Seat placement is perfect now!
Thanks guys . I'm very relieved to have the seat placement settled. Now, I can finally shift my focus toward wheels, tires, and sprockets.outskirtscustoms said:Looking killer, seat is just right, now get to building.
laidbackcool said:All of the clutter is gone, which creates clearance for the springs to rest comfortably on the fork hoop. It's impossible to tell in the photo, but the spring stay in the background has threading that ripped due to a rust frozen acorn nut. Either I will have the spring stays cut and re-threaded by an LBS or buy a new fork hoop.
laidbackcool said:The definition of delivering in the clutch. You my friend are a life saver! Thanks !deorman said:http://www.homedepot.com/p/Irwin-Fractional-Tap-and-Hexagon-Die-Set-12-Piece-24605SM/100352484?keyword=fractional+tap+and+die+set
My initial thoughts are leaning toward this combo:outskirtscustoms said:Looking good, what you thinking for bars? low slung drag bars or apes? Either one would look great.
I could be wrong, but my initial thoughts are inclined to believe that the rear will spring just a little since the truss rods are not bolted in the area where the rear axle will go. The only way I'll find out for sure is when I have everything in place to do a test drive. Even if it doesn't, I still like the springs purely for looks.kingfish254 said:Will the rear spring or is it fixed?
Thanks a lot! I'm having a strong lean towards this set from choppersus.com: 23" wide with a 16" pullback...pacman270 said:Looks killer dude. You got bars picked out yet?
I think you've been inside my brain because that's definitely a thought I've had regarding the larger wheels & tire combo, and I appreciate the fact that you've come out said it. I also agree with the rear fender needing to have more uniformity with the one in the front.deorman said:I think that the nice wrappy fenders contribute more to the overall image than larger tires would. I would probably roll the back fender forward to be the same rear length as the front, but sweeper works.
I like your design, but I have one question.... What is to stop the front wheel mount from moving upwards seeing as it looks to be only bolted at the one end of the black metal extension? Please show a closer picture of that are.laidbackcool said:Here's a quick mock-up with the fenders.
My initial concern with the fenders is that they'll limit the wheel and tire size I'm able to use, and that they may draw too much attention away from the tires themselves. I'm also having reservations about the rear truss rods in that they could eliminate the action of the springs. Any suggestions are more than welcome!
