I like the bottom section of that frame. Cool base for a chopper!
Now you need a cool stick shift.
Thanks, that's what I'm going for. Allways wanted one, since in Poland their very scarce, and I also never had the cash to afford one.
I'm going to try that Pierogi recipe ! I'm guessing 'bacon' could be substituted for 'pork rind' in the topping mix.
Yes ofcourse!
Does it work better to roll the dough if the roller is damp or dry?
If I recall correctly my Granny always used a slightly damp roller. Remember to only put flour on the table, and never on the dough, since it will not close properly!
Looking forward to the pics!
Awaiting our photos from you paint day. Funny that we were both at that stage of our builds yesterday!
So here they are, and yes
@OddJob it's actually not the only funny part about that...
But first, lets start with something else
I remembered that my neighbor's daughter had an old bike with the same banana seat that was the base for mine, so I took a picture of it for comparsion.
Yeah... the scale of this "customization" still amazes me.
While the paint was drying I started to work on the fork. First the hole for mounting the fender, headlight, and most importantly - the new front brake.
And it appears I measured it correctly.
By the way - this is my new front brake - Don't know the exact model.
And it definitely needed a rebuild, since it barely worked.
Way better. Also installed new brake pads with changable brake shoes from Shimano.
And the mockup with the wheel.
Also the headtube was too long by about 10mm so, had to shorten it. I know that I use Brutal Barabaric Slav Power in most of the cases, but this operation requiered at least SOME precission.
Time came to make a mount for the headlight. Good thing is that one of the mechanics in my shop also services lifts in the nearby blocks, so he has a lot of heavy & solid pieces of metal.
I think this will do...
... and yes it did the trick.
Thoses screws come real handy.
Nothing gets wasted in my workshop. Even the cut out piece of the headtube
Also had a second to think about witch set of pedals I want to use.
Still need to rethink this part, since I can't see most of them on this bike. Might try to look for other options.
So, where were we... Ah yes! The paint!
Bare frame ready for painting.
Primered.
Added the effect of multi-colored primers as a base.
As you may recall from another thread, I very much liked the color on the Author A-Matrix that is for sale in my shop. The one sitting on he rack next to the mocked-up frame.
@OddJob here is the real funny part
Eyup, also went with blue on this one.
Went with flat black on the insides of the fenders for contrast.
And here is the frame already in the stand. Also changed the quick-release to normal bolt for a better grip while I sit on the bike with my heavy bum
Since it's painted I can start to put it back together, and as I always do - started with the rear fender.
Reused the mounting posts from the old fender, and mounted this sweet old reflector. Also you can see the brand-new derailleur mount on the picture.
And again I couldn't help myself and made a quick mockup with the fork.
Till now I believe everything is "Big" when it comes to sizes in this bike.
More progress tommorow... or more exactly today, since it's 1:06 in PL. Need to get some sleep before work.
