There are lots of ways to approach freeing up a stuck seat post in a rusted frame.
I've been thinking of a way to do this without harming the frame, the paint, or even the seat post itself.
If they are really stuck, as you know, something usually has to give, and get destroyed in the process.
The goals of my experiment were:
Get it out of the frame with:
No harm to the frame
No harm to the paint or patina on the frame
Salvage the seat post if possible.
Since the hardest part is usually getting a grip on the seat post, I decided to approach it like this.
I have an old girls Schwinn typical of frames with really stuck seat posts, that I did not mind messing up it this failed.
I selected a bolt that would fit inside the seat post, and a drill bit the same size.
I drilled the top of the seat post out so that the bolt could be inserted into it.
I then took it to my buddy's automotive shop where he was able to weld the bolt to the seat post.
Here's where I got involved helping him and did not get a critical photo. ( sorry, imagine frame clamped in vice and impact wrench in use).
He used his heavy duty air impact wrench to get on the bolt/post and spun it free inside the frame seat tube, breaking the rust's firm grip.
Once it was moving, we clamped the head of the bolt into his vice and worked the seat post out of the frame.
Then he got out an air cut off wheel and removed the weld and bolt from the seat post.
Everything worked as I thought it would for once.
I bought him pizza for lunch. It's good to have friends who will trade favors.
