Sturmey Archer 2 speed/Skip tooth question
I remember SA and Bendix cogs not being interchangeable. But one can be modified to fit. I just do not remember if it is SA to Bendix or Bendix to SA. Just a little filing to fit. Now another item that goes unnoticed is that Shimano cassette cogs can be modified to fit coaster hubs. This is a great source for large cogs.
And Shimano 110 cogs have the same 3 lug drive as the old SA - SC and 3 spd.. The cassette cogs have the same center drive dia, but more drive lugs, you just grind out the unwanted ones to get the 3 lugs.
rlhender said:
The Ebay cog will not work on the S2C hub : (
which ebay link did you use...
Myself and a friend have both used the ebay sprockets and they work fine...just went for a ride here....
(just picked this up with a search....sorry for the late reply)
IIRC, the new kickback has a unique cog interface. Their 8-speed hub does as well, but I think everything else in S-A's line uses the standard three-tab design.
hubgearfreak said:
SA's S2C uses the same 3 sprocket arrangement as almost all other hubgears. i know, cos i've got one and changed sprockets.
You're right - I was think of their S3X fixed gear 3-speed hub. Sorry. :oops:
