Since I started working at the bike shop I learned a few things including ,S/A three speed adjustment.
Without having a picture for reference , basicly you have the cableside wheelnut with the hole in it, what you need to do is put the bike in second gear and while it is in second the edge of the rod where the shift chain attaches needs to be lined up with the inside edge of the hole in the wheelnut, make sure the rod is all the way tightened and the adjustment will be on the barrelnut where the shift cable attaches, took care of the neutral drop on mine :wink:
