as my old man would say: "good enough for the girls we go with!"
I like that comment.
The apes work well with the trike. Keep plugging away.
Thats a great tip, thanks! I found a smaller pipe to sleeve the joint, but it wasn't a very tight fit so the results are less than perfect.If you have another piece of tube about the same diameter as the two you are joining, cut it lengthways, crush or hammer one side of the cut a bit so that it just goes under the other, then hammer one end into bit you are adding, and then the other into the handlebar. It makes for a tight joint, and you can always weld it later.
I always thought it was kinda inappropriate cause he was talking about my mom... The more i think about it the more I realize it's pretty sexist and heteronormative too. Even an old queer like me has to keep thinkin about stuff like that as I grow.I like that comment.
I think I actually like "good enough for our gang" better anyway.I took it more to be along the lines of "good enough for the gang we hang out with", the gender part didn't even cross my mind.
