Have you tried a relatively hidden spot with #0000 steel wool and white vinegar? If the rust is mostly suface, you might lift up aome of the natural patina of the paint underneath.
What if you left the steering wheel on the handle bar, but cut the bars where they are tangential to the 'circle'. Then color the steering wheel spokes to match the handle bar or vice a versa. Blend right in.
My opinion, one or the other, both makes no sense.![]()
I'll be honest and probably anger some people, but it's just my opinion. I never liked the look of a steering wheel on a bike. Now THIS bike on the other hand looks great with the wheel. Maybe that's why I don't see adding the bars with it.You are probably right, but does this whole idea of a tractor hood on a reversed tricycle bike make sense? Are we here to make sense? Just a thought.
Lowriders have been doing this for decades.Playing around with hybrid steering system.
Ought to be one if a kind...maybe, suppose someone else has done it though. Let me know.
The original bars look great! Reminds you that it is a bike!
I'm also not a big fan of rust, probably because I'm a painter. But again, it fits this build perfectly. If you were to paint it, a traditional black with flames would look wild on this!
I don't remember if you ever mentioned it, are you putting a tractor seat on it?
The difference is that one is from the hood and the other is through the hood.![]()
And make them turn with the wheels! That should simplify thingsI forgot that you have two hoods. You should use both, one over each front wheel.![]()
Not going to happen. Might be cool though.I forgot that you have two hoods. You should use both, one over each front wheel.![]()
You are such a comedian...simplify things my (___), fill in the blank.And make them turn with the wheels! That should simplify things
Our state is opening everything thing up, basically 100% with no regulations, wish me luck.
We've been opening up for about a month now without major problems at all. I've already had more than 10 sit down dinners in restaurants. There were even a ton of tourists out and about this holiday weekend here.
The factory that the Bradley hood was manufactured in is a couple of miles from me. You can still see the Sears and Bradley logos on it. It is an industrial park now.
