Which Nexus 3 washer on a pre-war frame?
May 20, 2009
7,011
7,126
Isle of Hope, GA
26   0   0
As the title says, I'm looking to install a Nexus 3 coast on a a pre-war frame with rear facing, slightly downward, dropouts.
I've read to use the green washers or file the tab off and just cinch the rear wheel good and tight....
Looking for experiential advice guys, thanks!
Cheers,
Forget those tabs. Grind them down and crank down the nuts. It won't move. That's what I did with my prewar Schwinn frame and a Nexus 7. Hasn't moved yet. Gary
OK, this is a different frame than the one I plan to use, but it looks like it would work, just flipped it 180 degrees from use on a forward facing dropout. This may be because the dropout is not truly horizontal, rather it sits at 4:00-5:00 o'clock. I guess we'll see with the actual frame.
Stay tuned.....
on the bottom of that link, it says the 3 speeds only use one type of washer, on one side the belcrank can just be clocked to where it works. if I remember right, it just slips over a nut, so you should be able to pick between 6 locations. am I thinking of something different?
