Loving this build Yooth! Can't wait to see it done!
yoothgeye said:A friend dropped off an old moped tank today, I have to clean the rust out of it, but it's absolutely PERFECT!!!
Here's the way I suspect it was supposed to be mounted to the original moped:
Here's how I plan to mount it:
I love it! I will be welding in a top tube to better secure the tank, but the nose of the tank fits the head tube perfectly at either angle.
dracothered said:Spray some PB Blaster on there every day and you might be surprised, it might come apart.
yoothgeye said:dracothered said:Spray some PB Blaster on there every day and you might be surprised, it might come apart.
That's exactly what I've been doing.
There is a factory service manual online, I printed the 40-some pages of the original owners manual, but the service manual is much longer, so I just need to look at it online and see the process to remove the magneto, I haven't even tried yet, I've been more worried about the stuck piston, but it could be a combination of both.
Whitfield said:PW 50 ~ Hmmm Those parts are fairly easy to find. PW 50 CDi ignition upgrade?
dracothered said:Why would you lose the lights going with a CDI?
outskirtscustoms said:dracothered said:Why would you lose the lights going with a CDI?
2 reasons, one is if you swap the entire wire loom the dirt bikes and quads were not equipped with lights, Two is because it will allow the engine to get up into higher RPM's producing more current from the magneto and it blows the bulbs unless you rebuild the wire loom with voltage regulators, resisters, and such.
