Hi, my name is Tom, I'm 20 years old and live in Norway.
I stumbeled in here when I was looking for some inspiration for a kustom kruizer project.
I do alot of spare-time drawing and designing, and the latest project is a lowrider bike.
What I plan to do:
*Kustom chopped and welded frame with quick-release function
*Making the frame geometry comfertable to ride(no serious streching for bars - due to back injury)
*Racestyle front fork with suspension
*Dual front discbrakes
*Rear discbrake
*Steel-plate seat with suspension
*Mono rear-swingarm with suspension
*Need some sort of gearing system that will work with the monoswingarm in the rear
Now I need some parts for my custom frame-build, some parts that needs to be compatible with parts from choppersus.com
These are basically the parts I need to be compatible to the parts (forks, crank's and such)
from choppersus.com as the frame will have to be costum buildt to achieve the look and geometry I want for the bike.
I've found this site through asking on the slow'n'low forum and figured I could use one of the headtubes and the BB-shell from this site?
http://www.prestosell.com/cgi-bin/order.pl?ref=firebikes&fm=1
I want to do something like this on the rear swingarm, just with a disc brake aswell:
I'm gonna use a black 36-spoke disc brake downhill hub which uses a 20 mm axle.
The 20mm axle is to make it more durable as it will only be mounted on one side.
ChopperOlli helped me out abit with some tips on it
For the gearing I need to to something similar to this made by Gdad on the slow'n'low forums:
Any tips on how to mount 2 sprockets on one hub and make a system like this work?
I would also like to add a freewheel to my drivetrain setup.
Finally here's my design, hope for some feedback on it.
Hoping I can make all my ideas work with some good help from you guys,
because I know close to nothing about bike parts since this is my first bike build.
Best regards
Tom -aka- Dephota
What I plan to do:
*Rear discbrake
Best regards
Tom -aka- Dephota
