1HP ELGIN ''UndeadCustom'' FINISHED!!!
already playing with possibilities :nerd:
Fork is welded, adjusted, cleaned ,bondo'ed ,sanded and primed/polished and clear :happy:
-I tested the springs and they work great "on the stiff side"
-The bondo was just to make it all rounded and smooth around the welds
ill leave it ratty (rust/primer) for a bit , the time to find what ill do with the rear and witch paint job ill do ..
i might eventually drop the fork the more i can and widen the chain stay even more to use original drop outs , that way the bike would end up "level" with its right stance .... but this would involve ditching the rear plate witch took time to make :oops:,and redo some new front pivot plates:39::whew:
Fork assembly and testing tomorrow:dance2:
piece by piece , its getting there:nod:
"restored" this light
changed the cracked plastic lens for a glass one from a halogen light
still using the original reflective cone and 6-7v light bulb from the bike light
wired it on 4 x AAA batteries all stacked tightly in there , so no cable routing
still need to instal a switch , cause now i just plug the wire on the mounting bolt to switch it on
