1HP ELGIN ''UndeadCustom'' FINISHED!!!
+2 on the existing chainguard! Good looking bike. If it was sporting some wide, flat mtb bars, I may come and take it to my bike shed to meet some other rats..:nod:
Thanks! i thought about that , but did not actually try to ride with it tho, maybe i should ... (that stem tho , does not fit the style at all)
After ridding it for a short while and taking nice pictures , the cold weather is setting in and i decided to disasemble everything , get rid of the rear drop outs , stretch the frame even more to fit the wheel normally for eventually prep the frame for pain or else?..
but the 2nd try at stretching splitted the stay again , but this time it was worst and to far gone ,so i had to cut it , and and transplant some steal in it ...
that is as soon as i buy a replacement vice :doh:
R.I.P vice n*1 (1991-2015) my loyal diy buddy since the begining:praise:
Yep! :D
and a little 3d preview of how ill be fixing the chanstays.
since the tubes are oval and of an awkward diameter (of tubing pressed oval) ill be using 5/8"tubing , bent to match the curve of the stays ,splited in length and welded slightly apart from each other on the 1/2" rod inserted inside (witch fits perfect in the narrow side of the oval stays)
Its almost finished welding, i should bring it back from makerspace tonight
i learned to do it myself last night , not that hard when you get the twist :)
the hope to be in the "from scratch bulds" section is getting closer and closer
i am planning to buy a welding machine and in the process of building a tube bender
Well that suicide stand was not working out ...
Not much updates lately , but i have been working on allot of small details and parts,
but also on a low flat bead cargo bike trailer witch ill show later or in the *Show me* fumum..
-replacing allot of hardware for brass
-making the suspension/light support out of a rusty flat bar
-redo the wirering and brushed aluminum finish on the light
-rebuild the pedals with custom peices of unknown dark oily REALLLLY hard wood
-rebuild the seat support polish/clear/new springs/brass nuts
more shiny than expected :39:
That textured color is a near perfect match , there was also like 4 other slightly different shades of brown available , glad i picked the right one:praise:
the baige-camo and black was use as a slight mist to to mimic the un-perfect natural patine
i think ima sand it a little smoother and use a flat/mat clear instead
every parts , nuts n bolts are prepped , but waiting on a possible vintage 3speed hub from a friend to do the wheels
also i think the end result might look along the lines of this:
a bit of a Jurassic theme with the (1hp) and (38) kind of hidden in there:) 38 for 1938 being the the middle of the 3 years of production of this bike frame 37-38-39
