Putting 8 speed shimano alivio derailleur on my Schwinn Heavy Duti.
Problem is chain from donor bike too short using the method defined by Sheldon Brown running chain over largest sprockets and adding 2 links. In the effort to save a buck, I'd like to see if a donor bike can provide the extra chain. or worst case I will buy a new one. Looking at Amazon seems there are chains rated up to 7 speeds and 8 speeds and over take a different chain.Also there is this pic,
Where a user says, "At less than 8.5mm maximum plate diameter, this chain might fix skipping in high gear caused by too large side plates riding on the spacer between the two smallest sprockets. Sadly, this critical specification is never published for any bicycle chains. The second photo shows various bike chains, all with the same pitch and 3/32" sprocket clearance. The third photo shows wear on the small sprocket spacer caused by a chain too big in diameter: if the chain rides too high, the following sprocket tooth can kick it up and cause the chain to skip."
So all 3/32 chain is not equal???
