I am working on my new tryke. See it in fresh finds. I want to make it one speed because the old 5 speed parts are junk. How do I align the chain if I use one of the existing large sprockets? You cant shift that cassette over. The hub is on the axle via roll pin. The only idea I had was changing to a single 22t freewheel then align7ng the hub and welding in place. Does a chain have to run perfectly straight to work or can they run at a slight angle?
Sent from my GT-P5113 using Tapatalk
