I was throwing out some stripped bikes, cut the back off a 26" frame thinking I could make a quick wheel truing stand out of it.
The wheels I've trued were bolted into the original frame and I clamp a magnetic base dial indicator to the frame and go from there.
I really like the dial indicator, you can see little blips at each spoke and the set up literally shows you what to do, right or left.
I can do the same with a cut off frame, but need to account for different width axles.
Weld some slotted angle to the sides of it for quick set up of dial indicator to check true. the frame also has v brake mounts that can be utilized.
Some type of sliding plate, or rigid plastic to check roundness.
Any ideas on setting up different width axles quickly? I considered coupling nuts, but I doubt I'll find them in 3/8-26. I guess I could buy a $10 tap, then I'm making multiple spacers.
