(Class 1 MBBO#4) Cycledelic - seat fabric lol
Haha! It's the other way around.
Paint depends on which wrap I use.
But I originally envisioned the blue green black.
Carl.
Ah! I see! I actually agree with you, paint is the easiest thing to change to get things to match.
My paint colour was decided on because of the fabric I chose for the seat...
Stem mount is the last resort... I want something wild and different. Love to fab a console, the twin frame is crying out for it... May do the stem mount just so I can see if the Sturmey will shift the Shimano....
Carl.
How 'bout using an old 8 track tape case, or Pong controller, or a shift cover from an old car for your shifter mount? Something from the era....probably would have vinyl wrap on it...:nod:
Does reshaping the body that much mess with the sound?
Well it has a different resonance to it now, and I wouldn't put it up against an American Fender by any standards, but it does sound fine. Of course I have no idea what it sounded like before, it was a husk when I got it.... ESP had Grassroots made a limited run of guitars like this a few years ago, they were marketed as "travel" guitars...
Carl.
Got my shifters from yeshoney...
Sturmey Archer 2+3... got me thinking about my drive train...
[...]But I do like this piece! I've never seen a shifter like this before, or the combination 2 speed on one side and 3 speed on the other... What bike had that?
Well - according to Sturmey Archer, these shifters were Space Age Equipment for the Cycles of the Seventies :bigsmile: - your shifter shows up on page 2 ...
So this is a double shifter meant for use on the Sturmey Archer S 5/1 5-speed gear hub, which in fact was a 3-speed hub with an additional planetary gear activated by the second shift lever on the left side.
Will this SA work with my Shimano 333 three speed?
I am not quite shure about that - Sturmey used a bell crank mechanism (only) on the first iteration of the 5-speed hub, but they used it for the additional planetary gear on the left, not for the basic three speed mechanism.
And as far as I know, the basic Shimano '333' 3-speed hub was not a copy of any existing 3-speed hub - the internal mechanics are different from Sturmey Archer and Sachs/SRAM gear hubs, so I doubt that the shift ratios inbetween gears will be exactly the same (and the proper function of any geared hub very much depends on exact shifting steps ...).
So I think you may be better off looking for a Sturmey Archer 3-speed hub - maybe you'll even find a drum brake version ... ?
Yet another possibility would be to use two sprockets and a derailleur on a Sturmey Archer 3-speed hub - as far as I know this option was never offered offically by Sturmey, but British cyclists did this as a hack already in the 1960s. And Sachs offered a 2x3 kit for their 3speed hub back in the day. And yes - it worked on the coaster brake versions of this hub.
Yeah I kinda figured the shifter would be proprietary... and I just built that rim with the 333 Shimano...ha, at least I have the correct thumb shifter. I've actually been looking at that thumb shifter and brainstorming the modification of it into a console shifter. Thanks for the info I did find out it was from a 3+2 bike and read about it some...
Carl.
Cool looking shifters there Carl. I'd think the 3-speed one might be worth trying to see if it will shift the Shimano. They made some wild shifters for those.
I like the green/blue wrap. Cool guitar.
