I need help diagnosing a problem with a Shimano E-110 coaster brake hub; I've never seen anything like this before and I'm hoping someone else has encountered it.
I have a factory built wheel that I bought before I could lace wheels myself; it's one of those Shimano E-110's laced to a Wheelmaster rim. Last winter I tried converting a mountain bike to single speed and threw the wheel on there. I noticed that as I pushed the bike forward, the crank arms (three piece crank) moved with the wheel. I figured it was something due to my inexperience attempting such a conversion and haven't touched the wheel since.
The rear wheel on my wife's winter bike needs to be trued a bit, so I thought I'd throw the Shimano E-110 wheel on there as a temporary replacement. Same result - it turns the crank arms (one piece cranks) around as you push the bike forward. I flipped the bike upside down, cranked the pedals a few times and let the wheel coast a bit - as it coasts, the crank arms seem like they're fighting some kind of tension; they fidget back and forth.
I know the cones are adjusted properly; when the wheel isn't on a bike it seems to spin fine (but you can only spin it so fast by hand). I have already cleaned it out, lubricated everything, and repacked it just like I have successfully done on so many similar hubs (KT's, Shimano D-Type's, etc.). I just can't figure out what's going on. Any ideas would be welcomed. Thanks!
