I've built up a few Komet Super hubs over the last few years and they have become my coaster brake hub of choice. However, today I started working on one with an oil port for the first time, and I have a few questions:
1. Even though it has an oil port, can I still just lubricate it with grease as I would a modern coaster brake hub? More importantly, would there be any actual advantages to using oil instead? I plan on overhauling it at least annually anyways, so the "less maintenance" advantage kinda goes out the window.
2. The sprocket is threaded on (I believe the later versions of the hub used a snap ring). It's an 18t; I'd really like 19t. Does anyone know what other threaded cogs are compatible with this hub? I cannot currently get the lockring off, so I can't get a TPI measurement, but that brings me to my last question:
3. Is the lockring normal threaded and the sprocket is reverse threaded? Or do I have that backwards? This doesn't seem to be documented anywhere.
Thanks!
Thanks!
