- Joined
- Sep 17, 2013
- Messages
- 4,278
- Reaction score
- 9,446
I have had this 30s Snyder for quite awhile. I work on it and then loose interest and then work on it again. I got it cheap because the seatpost tube was broken off from someone putting the 5/8 inch lucky 7 seatpost too high. The lucky 7 was then sloppily welded on, probably years ago, with a stick welder. I got a one inch steel rod and drilled a 5/8 hole in it with my drill press. I then cut off the lucky 7 seatpost. I drilled out the old seatpost. I plan to insert a 5/8 rod through the hole in the one inch rod and into the frame. I will hold it in place with magnets and tack it in place once I clean up all the cutting oil. One of my buddies is a fabricator and a riding partner and he will do the final welding. I don't know when I will get around to finishing it. I have everything, I just need motivation.
Here it is with no seat post clamp with the lucky 7 welded onto the frame.
It's cold outside so I did the cutting and flat filing in my front hall.
Seatpost cutoff and ready to be flat filed.
Sometimes things work out as you hoped. The seatpost was only in the seatpost tube about 2 inches so drilling was a snap. I did bust off two smaller drills making pilot holes.
Mock up. I may cut it down shorter but I will have to consult my fabrication buddy first. I feel that a taller clamp would reduce some of the pressure around the brazing when the clamp is tightened. Any thoughts on this worry, or am I fussing about this needlessly?
