tikiharl said:I needed to come up with a basic inexpensive jig to make my next Burrito build a little more precise than "hows that look?" and ''hold this while I tack it". I had always thought the unistrut idea would be a good way to go,mostly because of the adjustments that could be made. On this I used 6" conduit spacers ,8" bolts and 3 sticks of unistrut. I even have a small crossbar that in theory could hold the BB in place,the BB should be craddeld in the open area of the unistrut. It needs a base,some metal or wood cross pieces to secure it. It folds pretty flat as well. It will be put to the test,and any modifacations made this Sat.
this is right up my alley. I'm no engineer but this looks simple enough. I'd rather spend my time working on the bike and this seems simple enough even I can build it. Is there any lengths of ini strut I should use? If not I'll assume the holes are pretty much the standard and just count the holes on yours to come up with lengths. Thank you everybody for sharing your ideas.I needed to come up with a basic inexpensive jig to make my next Burrito build a little more precise than "hows that look?" and ''hold this while I tack it". I had always thought the unistrut idea would be a good way to go,mostly because of the adjustments that could be made. On this I used 6" conduit spacers ,8" bolts and 3 sticks of unistrut. I even have a small crossbar that in theory could hold the BB in place,the BB should be craddeld in the open area of the unistrut. It needs a base,some metal or wood cross pieces to secure it. It folds pretty flat as well. It will be put to the test,and any modifacations made this Sat.
The whole work area and my home made frame clamp -
