Lock three speed to one gear
If you can lock it into direct drive (2nd?) gear you might be a little better in the efficiency department than the other gears.
Well my brother did not have anything I could use so have ordered the chain gear indicator off ebay will then have to figure out how to fix it into a single speed [maybe a pipe clip to the frame??]
MrG
Got rear tyre and tube fitted but made front look awful so ordered a tyre for the front!
Gear chain has arrived so hope to get it fitted next few days
MrG
Would prefer a single speed... but was quoted £60 [$95] for a complete rear [tyre, tube, wheel, single speed cog]
If I come across a three speed hob I will let you know
MrG
Well got gear chain and trying this idea...
Will need washers and a nut to lock it...but it still allows me to find gear I want and of course still be able to remove the wheel for maintenance
Cable fed through top tube, tractor seat is now history... will paint up during winter months still not sure about stand
I lost track of this thread for a little while. Why let a perfectly good eyelet go to waste?
I like the hidden cables too. Did you drill the top tube for the cables?
Top tube is drilled then I angled drill, holes are on opposite sides to allow cable to flow...
Put some tape around end of brake cable and once fed down tube .... fish it out other end. Cable cover simply follows path of brake cable
You will find that you can cut a the very least 6 inches of cable and cover, all saves weight...
My only concern is wear [at front of top tube] on cable sleeve, my dremel packed up at just the right time... :lol:
Hope this helps
MrG
