Mirror mount fab for a single post mirror.
The mirror had a broke off siezed post, that I trimmed down for clearance.
Then, I took a M6 clip nut and trimmed it in to where the cables used to pass thru.
For the mount, First I took an old left hand thumb shifter and took it apart, tossing most of it.
I took the base of it and ground a round edge to use as a cam opposit of the slot. The tab that went in the slot to follow the new rounded edge.
I also took a 3/8 bit and hogged out the smaller hole in the base to slide the mirror into.
Then I polished the inside of a stainless M6 machine screw, a stainless washer and the bases. A rubber grommet sliced down the middle agaisnst the bracket.
Lubed with moly graphite, and bolted it together as almost as tight as it would go.
The tab and cam keeps it from going too far.
Moves with resistance only.
Took cloth backed vinyl, masking tape and a blow dryer to get a little goo on the cloth. Then mounted the new mirror to the handlebar.
Last thing will be to mount a glass in it.
