So… you may remember this brace with the giant hole in it.
Since it’s not being used, that hole is an eyesore. My original thought was to to fill it in. But I want to make it look like it was never there. I think the better way to do that is to replace it. So I snagged some 1/2” tube from work (which has a considerably thicker ID than the original, but oh well)
And I’m going to replace the brace, then relocate the tab. I may even move the brace up slightly and keep the distance. And I may make the brace wider to keep better spread in the stays for the fat tire.
Whatever I do, it means I’m going to cut a piece off the original frame and replace it with a non-original part. Because if that, even though my goal is to make it look original, in the spirit of the rules, I’m going to move this build to the “Unlimited” class.
![1716486384557.jpeg 1716486384557.jpeg](https://cdn.imagearchive.com/ratrodbikes/data/attach/266/266968-1716486384557.jpeg)
![E4EF6A74-B853-4A0D-B9BC-9E1250DB3088.jpeg E4EF6A74-B853-4A0D-B9BC-9E1250DB3088.jpeg](https://cdn.imagearchive.com/ratrodbikes/data/attach/266/266969-E4EF6A74-B853-4A0D-B9BC-9E1250DB3088.jpeg)
