I saw a picture of a Model T bicycle today. I really want to make one! Has anybody attempted this? I just think it would be awesome to make! Thanks! 8)
Yes I do, if I can find them I'll post them here.Vintagebikebuilder said:Do you still have them? It would be nice for a head start!
outskirtscustoms said:Yes I do, if I can find them I'll post them here.Vintagebikebuilder said:Do you still have them? It would be nice for a head start!
outskirtscustoms said:Okay here's some of the plans that I had to build mine. I too have really limited storage space so I gave up on the idea for now. My design also incorporates a full suspension / adjustable ride height system. Here's the basic idea behind the chassis. The fenders and wheels would move independent from the body to allow for ride height adjustment and suspension travel. First cut up two girls frames as such.
How would you create the axles?
Vintagebikebuilder said:outskirtscustoms said:Okay here's some of the plans that I had to build mine. I too have really limited storage space so I gave up on the idea for now. My design also incorporates a full suspension / adjustable ride height system. Here's the basic idea behind the chassis. The fenders and wheels would move independent from the body to allow for ride height adjustment and suspension travel. First cut up two girls frames as such.
The idea I was thinking was to just make a very basic frame out of square stock and make some hinge brackets to hold the frames from the crank housings and weld in some points to mount shocks and such. I'll revise a few drawings and post them when I'm done.Vintagebikebuilder said:This seams very interesting. What is you took two identical bikes.. And sorta welded them to some supports? Then build around what
No problem, just remember all of my designs are from thoughts and brainstorms, not tested, attempted, built, or guaranteed to work.Vintagebikebuilder said:Alright, Thanks for all your help outskirt!
outskirtscustoms said:No problem, just remember all of my designs are from thoughts and brainstorms, not tested, attempted, built, or guaranteed to work.Vintagebikebuilder said:Alright, Thanks for all your help outskirt!
If I tried it, I would use this basic design, but bring the front wheels forward like a stretched front beam on a ratrod car. Then I would bring the cranks forward and lower the seat. It would position you between a standard bike stance and recumbant, but you would be sitting more like in a modern vehicle. Then chop the top to get it more like a rat.Vintagebikebuilder said:Here is the pic I saw
ozzmonaut said:If I tried it, I would use this basic design, but bring the front wheels forward like a stretched front beam on a ratrod car. Then I would bring the cranks forward and lower the seat. It would position you between a standard bike stance and recumbant, but you would be sitting more like in a modern vehicle. Then chop the top to get it more like a rat.Vintagebikebuilder said:Here is the pic I saw
