Mount spaceliner tank
Jun 22, 2014
982
530
Nebraska
1   0   0
Feel like a total noob for this but...
How does the straight tank mount to a spaceliner frame?
I know the tank opens and goes closed around the head tube but what holds the back end of the tank up to the underside of the bars?
Hard to remember, as it's been a while since I took mine off. I think there is a tab welded to the frame, and the back end of the tank screws into that.
If you don't get a good answer soon, I'll go home and check mine out to verify.
Thanks guys i will need to figure something out to make this work.
My frame is a 7 tank frame but I want to attach a straight tank I have.
What's this washer trick? A picture would be worth a thousand words probably.
Didn't think it would matter lol never seen a pic that showed a mounting point so I thought it was on the tank side & I was missing something
Curved plate that is welded to the underside of the downtube that the bottom of the tank tab slides into.
The straight tank has a u shaped tab on the underside of the bottom tube under the double top tubes with two ears facing the headtube that slide into the two tank halves end openings.
Have a picture somewhere.
It's all about the Tanklights!!
How did I run out of room so fast?
@CeeBee got any pics of your washer method?
Tanks guys figured there had to be something welded on but couldn't find a pic to confirm.
So basicly bend a washer to fit on top the tubes and cut a piece to slip in the end of the tank but with a hole in it to bolt it all together to hold the tank up.
Think I can manage that.
Here's what I have
I have the straight tank model. At the rear of the tank, welded to the frame, is a steel tab that looks just like an automotive front end alignment shim, just narrower and thinner. The pronged end faces forward and slides into a corresponding slot in the rear of the tank.
