Thanks guys!
Here a little update on the crossframe bike:
I tacked the CroMoly together and am working on the chainstay right now.
Bought a "Salt Rookie" 175mm crankset which is servicable with normaal tools
The tacking is a bit tacky
I am not a professional welder. I will let the finishing welds be done by a professional welder.
The measurements and alignment is very good!!
Not perfect... but it stays there!
29+ or 29x3.0 tires (Probably Surly Knards) with 68mm bottom bracket is a bit of a challenge to fit. So I made a quick 'n dirty 3D model with 550mm chainstays (this is a large bike!) and 80mm's wide tires.
The green plate is a 5 or 6mm steel plate that will be connected to 20mm CroMoly tubes.
Again, a quick and dirty test model, rounds and plate bending to be added.
So 2x 20mm tubes between the bottom bracket shell and this plate.
And 20mm chainstay tubes to the dropout.
Dropout wise I am thinking about inspiration from a real nice one that I saw: Speedholes
