Curious about the amount fuel capacity? The rule of thumb is approximately 1 ounce of fuel equals 10 miles.
Time in the saddle on a 2 stroke is about 25 miles, before the comfort dissipates.
Jake, you are a bad man. Ha, ha.HEY WATCH IT MISTER...KIDS COULD BE READING THIS...![]()
Sent from my SAMSUNG-SM-N900A using Tapatalk
Given those perameters I probably could've kept the tank at the normal size.Curious about the amount fuel capacity? The rule of thumb is approximately 1 ounce of fuel equals 10 miles.
That's a really good suggestion, I will definitely explore that idea further . Thanks!You could also run a bolt through the mount and the plate on the outside mounts as kind of a safety net? Just have a nylock nut or lock nut so it doesn't compress the rubber.
Loving the mad scientist aspect of this build.
