Road Rash
marshall hudson
RRB Supporter
Pro Member
Sep 10, 2014
307
1,352
Found the correct tank this week. Not a dent anywhere. Its the color the bike originally was. I just have to take the shine off it and it will be ready for striping. I plan on getting caught up some tomorrow. Work and swap meets have been taking up all my time lately.
May 20, 2009
6,988
6,998
Isle of Hope, GA
Wow i just searched the forum and that stuff is awesome! Curious to see how your frame will look after the treatment.
Not so sure how my wife will react if i put it in the bathtub😅
Go to Walmart and get a kiddie pool. 😉
marshall hudson
RRB Supporter
Pro Member
Sep 10, 2014
307
1,352
Back from slackerville. Finally getting some free time. I'm still digging out parts and pieces. Pulled out some hub caps i'll repaint later and a different chainguard that might fit. Also have a set of torrington bars with good patina and a deco stem.. I had to buy another set of dropstand bolts because i put the last set up somewhee so i wouldn't lose them. That didn't work. And a bunch of fender rivets. I still need to decide on what color tires to use and which handlebar grips will work. Some cleanup work the next couple days and should be back on track.
marshall hudson
RRB Supporter
Pro Member
Sep 10, 2014
307
1,352
Did some mocks up today and so far everything works. I pulled out a set of monark springer forks that fit fine, i'm missing the bushings but i can make a set at work. I'll also need to dimple the front fender to fit. I also got out another springer set i wanted to use but i can't find the top bracket or nuts. i mounted the paisley sprocket and cranks i picked up. No prob with them. The chainguard will work, i just have to reattach the front bracket in a diff location. It appears chrome under the flat black paint job. Not sure how i will finish it yet. Handlebars and stem work ok. Seat and stem are good. If i stay with this seat i may change the color later. I still need to find tires and grips but it's starting to come together.
marshall hudson
RRB Supporter
Pro Member
Sep 10, 2014
307
1,352
Finally got a kiddie pool for the oxallic acid bath. I filled it up last night and loaded some parts. I pulled the fenders out a bit ago and wiped the white film off. I could already see a big improvement. The frame barely fit but it's all in. On a side note , i found my next build project this week. Someone thought they should make it a Schwinn with the headbadge with big machine screws and the decals. They also drilled an off center holes for a kickstand. I only have the frame but until next May to collect parts. I ran the serial number and it shows it to be a 1939 Murray. Looptail and curved down tube.
Jul 25, 2016
1,126
1,873
Chicago - far west burbs
That thing is dripping with style the way it sits. See how it looks coming out of OA bath, looks like plenty of paint there to take a hand polish. The "glow" of cleaned up faded paint is really nice compared to a flat clear. Looking forward to see where ya go with it.
The Murray, WOW.
marshall hudson
RRB Supporter
Pro Member
Sep 10, 2014
307
1,352
After everything came out of the ox bath i wasn't excited about the results. I may have left it to long. The fenders came out maroon and bare metal that turned a nice brown. Those i liked. the frame came out more red than i liked. So after a day or two of looking at it i decided to just go naked with it. The wife told me to get my clothes back on and fix the bikes finish. Out came the aircraft stripper and i removed the red. I've always wanted to do a bare metal finish. After stripping the frame down i put it back into the oxalic bath for about 24 hours. After cleaning it off real good it had a pickled look. A couple of coats of dead flat clear and i really liked the look. I plan to leave the original paint on the tank after i take the shine off of it. Fenders will stay as they are. A good striping job should tie it all together. Maybe not my best idea ever but i have a plan.
Pro Member
Aug 31, 2009
31,854
39,597
Historic Savannah
marshall hudson
RRB Supporter
Pro Member
Sep 10, 2014
307
1,352
I managed to get a little more done today. I mounted the monark springer I stripped and clear coated. New bearings and it turns like new. I still need bushings but I'll prob make my own. I stripped the chain guard down and did a lot of sanding filled by a coat of clear flat. I put two layers of copper mesh behind the holes to make it pop. I will be using more copper accents as I go along. Tank next and then drive train. I'm waiting on some master links now.
marshall hudson
RRB Supporter
Pro Member
Sep 10, 2014
307
1,352
That copper mesh backing is cool!
I started with one layer and it looked ok when the the light hit it right. The second layer made it pop. I made a template and cut the copper screen to fit. I used 3m 77 spray adhesive to attach it to the back side.
Pro Member
Aug 31, 2009
31,854
39,597
Historic Savannah
Very cool effect with the copper mesh!
