Shimano three speed coaster cable replacement
Fv2
Don't know what I'm doing, gonna do it anyway.
Apr 17, 2014
7,314
11,637
ohio
40   0   0
I just dug through my parts stash and found an old three speed hub, how do I install a cable so I can make sure it shifts proper.
It has an end like this.
Does it come apart and lock the cable in place?
Sent from my LGL34C using Tapatalk
I had a 3 speed shimano with a hookup like that. It's hard to explain, a pic works better:
Here's a vid on shimano 3 speed.
Hey, thanks Wildcat.
Does your hub have a bellcrank, like shown in the video, or does it have a small chain? That style of barrel adjuster can be found on either type, but the adjustment procedure is slightly different.
It has a bellcrank
On most older shimano 3 speed hubs, there's no port for oil. What I do is take out the shift rod and add light machine oil, into the axle hole. Then I install and push the rod a few times to work the oil in. That seemed to get most of the inner gears working well.
This one has an oil port, so I'm guessing it's late 70's/early 80's. It also has a plastic protective cover on the bellcrank. I took the push rod out and the oil looks clean, and the mechanism works fine. I just haven't hooked it to a chain to see if it shifts.
