Everything I order seems critical.
That's what I do.That’s incredible! This is fascinating because I’ve never dialed a bike back to a barn find state. Great work!
The brakes themselves feel a little inadequate
The chain guard is an iconic part of these particular muscle bikes! Don't give up on it yet, pictures will be coming soon.Hard to believe it's the same bike you started with. Personally, I'd leave the chain guard off, but I realize that's all part of the image.
That is actually the same spring!I see you replaced the spring? What’s it seating against? And it’s pushing back the…. Knarp? I’m just trying to understand the mechanics. I think the point of the spring is to hold tension on the cable so the lever snaps back into place rather than the housing falling out due to it being slack. But just exactly how it’s “supposed” to work is a mystery. I’ve just figured out solutions, but never the same one twice.
Bike looks great!
Thanks for the props!This bike is amazing!
I have a theory. The brake cable routing creates an S shape. I had a similar issue with brakes that had no power. I tried everything and couldn’t get power. Finally I re-routed the cables to avoid the S shape and the brakes worked again. Seems like if the brake housing bends in opposite directions like an S it causes problems. If all the bends are in the same direction you get more power.
Just a theory, but might be worth playing with.
There's the trick! It seats against the ferrule. I think the springs I got were too large in diameter....The spring itself passes through the 'long adjuster-looking part' (for lack of a better term I'll just call it the adjuster) and 'seats' against the cable ferrule...
Start at the center of the bar, where ever you want the end of the tape to be. Tape the edge to the bar, then wrap over it once, then start the angle. The rule I've used in the past is "half", meaning I would use half the width to cover the other half of the previous spiral. I hope that makes sense. But if you don't have enough tape you may need to move those edges closer to each other. Keep it TIGHT. Especially if the edges are close. It looks like they clamped the levers over the tape in the add. I've never done that as I'd fear it would cut the tape because you'd have to crank it down to keep the lever from moving. So I'm going to try a road bike trick on mine, make sure the bolts aren't protruding, and use an "X" pattern to wrap over the levers if I can. Do what works for you. When you get to the end of the bars give it a flat wrap so you cover all the chrome at the end, you should have some excess after that. Stuff that into the bar and use the plugs to "seal" it.Any advice or tips from the pros before I start?
